3cx softphone
Discussion in '3CX Phone System - General' started by jonas vanhulle, Feb 16, 2018.
  1. jonas vanhulle
    Feb 16, 2018
    The 3cx softphone shows during the first 30 seconds my contacts but then they dissapear to never be seen again, unless i restart my phone appliction and then for 30 seconds i see my contacts
    even my office 365 contacts dissapear after 30 seconds
    also there is no call log wich used to work a few months ago
    tried disabling firewall also didnt help
    also there is a second problem that if we call a number wich has options even if i press them a hundred times the options wont be given by us
    not on softphone or on the yealink phones
    the pbx is on version 15.5.6354.2
