3cx Softphones can't able configure in Samsung S7 & S8
Discussion in '3CX Phone System - General' started by raja_3cx, Mar 8, 2018.
  1. raja_3cx
    Mar 8, 2018
    I cannot able to configure the 3cx softphones in samsung s7 & s8.
    In other android phones it is working.
    Pls advise.
    TIA
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,108
    166
    Need more info, what do you mean
    Can not import the config file ?
    Have you tried scanning the QBR code
  3. raja_3cx
    Mar 8, 2018
    Yes. Tried both method (tried to open configuration file and QR code also. no response).
    Not working.
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,475
    94
    What does "not working" mean?
    Can you give some more details?
    1) Config File:
    -Download the config file to your Android's download folder.
    -Download Total Commander on your Android from the app store.
    -Open Total Commander
    -Browse the "Downloads" directory
    -Find the 3cxconfig file
    -Click it
    -Select *Open With
    -Select *Open With 3CX
    2) QR:
    -Go to Management Console > Extensions
    -Create an extension. Make sure you put a valid e-mail when you create it.
    -Once created, click on the extension in the extension list and press the "Send Welcome Email" button on the top.
    -Open your E-mail.
    -Go to your PBX's WebClient page: yourcompany.3cx.eu:5001/webclient
    -Type username and password found in e-mail
    -Login
    -Go top right
    -Click on your Avatar/User Image icon
    -Click on QR Scan
    -Scan it with your 3CX Android App's QR scan feature under the "More" tab.
    What doesn't work about the above?
  5. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
    Using the QR code you moved the mobile phone closer to the screen? I had the same issue I had to move the mobile phone forward enough until it registers.
  6. dredd0606
    Feb 14, 2018
    42
    13
    We recently deployed to an organization with 26 Samsung S8+ as the corporate cellular devices, and were able to provision the smartphone client easily by opening the "Welcome Email" attachment on the devices once the softphone was installed from the Google Play Store.
