3cx software client can't here menus
Discussion in '3CX Phone System - General' started by glennbtn, Apr 15, 2008.
  1. glennbtn
    Mar 14, 2008
    I have 3cx installed on a test pc with the 3cx client software and a snom300 connected to the system for testing. Thge snom has no problems at all but when I try to dial in to the voice mail menu or the ivr menu it say connected but can't here anything. Normal calls seems fine.
    Any ideas
  2. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Could be a missing CODEC on the PC. Have you tried here? http://www.3cx.com/forums/dumb-new-user-question-4084.html#p18561
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    You mean you have installed the VOIP client on a separate machine and you can not make calls from it? Check server status logs to see if connection is OK. Woudl seem some firewall problem o rnetwork connection problem on the machine on which you have installed 3CX VOIP client
  4. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Sorry, I may have mis-interpreted the question. I thought that "glennbtn" could establish a call from the PC softphone but could not hear any audio, hence the comment about a missing CODEC. Perhaps glennbtn could clarify the issue.
