3cx some outgoing calls does not disconnect.
Discussion in 'Windows' started by Rajesh2, Jun 14, 2016.
  1. Rajesh2
    Jun 14, 2016
    We have 3CX verison 12.5 with 2 SIP trunk.
    One outgoing call was in connected state for 3 hours even when it was disconnected with in a minute. However when I checked the recording for that call I see that recording is only for 32 seconds.
    Same extension has made 15 calls to the same number with out any issue. I am not sure why 1 call show connected state for 3 hours.
    Kind regards,
    Rajesh
  2. SAlih
    Dec 5, 2016
    i hv also the same problem, any solution ?
