3CX - Source identification issues
Discussion in '3CX Phone System - General' started by sebastian.rojas, Feb 17, 2017.
  1. sebastian.rojas
    May 30, 2016
    14
    Hello all,
    finally i know what happen with 3cx and my pstn gateway
    3cx received a unknown re-invite
    INVITE sip:9400@172.16.101.100:5060 SIP/2.0
    i was looking for some info and i found this,
    https://www.3cx.com/blog/docs/source-identification-issues/
    i have to change the inbound/outbound paremeters to make 3cx recognize the invite from the pstn gateway?
    which are the best options to do this, user part/host part, can i use some kind of wildcards?
    Thanks for your time
    Best Regards
