- Joined
- Feb 21, 2010
- Messages
- 4
- Reaction score
- 0
Having spent no less than weeks trying to config the 3CX to work in my home I still have some hurdles ;-(
Background: I thought IP telephone in new house would be good idea. After reading bought the following: Laptop to host 3CX (win XP), Snom 870. I managed to get IP internal network calls working and SKYPE working (yipee). I then discovered not possible to make PSTN calls so bought also a Linksys SPA 3102 as it is supported by 3CX. The SPA3102 is conneted to the laptop hosting 3CX via a router.
Problem: Setup the SPA3102 and can still mak all my IP internal and skype calls; the 'Analogue Gateway' is registered(idle) and the outbound rule appears to be OK. From PSTN, incoming calls just does not reach the PBX and my outgoing calls terminate immediately. I receive the following in the log file:
15:18:33.448 [CM503008]: Call(3): Call is terminated
15:18:33.148 [CM503007]: Call(3): Device joined: sip:[email protected]:5062
15:18:33.128 [CM503007]: Call(3): Device joined: sip:[email protected]:3072;line=5pcbubo6
15:18:33.068 [CM505002]: Gateway:[Analogue Gateway] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:[email protected]:5060]
15:18:33.068 [CM503002]: Call(3): Alerting sip:[email protected]:5062
15:18:32.977 [CM503025]: Call(3): Calling PSTNline:621XXXXXX@(Ln.10003@Analogue Gateway)@[Dev:sip:[email protected]:5062]
15:18:32.867 [CM503004]: Call(3): Route 1: PSTNline:621XXXXXX@(Ln.10003@Analogue Gateway)@[Dev:sip:[email protected]:5062]
15:18:32.857 [CM503010]: Making route(s) to <sip:[email protected]:5060;user=phone>
15:18:32.847 [CM505001]: Ext.100: Device info: Device Identified: [Man: Snom;Mod: 8xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom870/8.3.2] PBX contact: [sip:[email protected]:5060]
15:18:32.747 [CM503001]: Call(3): Incoming call from Ext.100 to <sip:[email protected]:5060;user=phone>
Not sure if my PSTN Line config is correct for LUXEMBOURG (P&T); in fact not really sure if this is the real problem but it appears it may be. The 3CX guide says to not enable line 1 - perhps I should try to get this to work first before trying to use 3CX also (?).
Would be very grateful if someone could point me in the right direction as my wife is seriously asking why I spend so much time, effort and money trying to setup this when a simple analogue phone for £20 would of been much better (well it would work she correctly says). Now using mobiles for all calls. PLEASE HELP as I think this could be really great setup and I feel pretty close to getting it to work (just PSTN Voice Gateway is the final hurdle) ;-/
