3CX, SPA942 not showing lines.
Discussion in '3CX Phone System - General' started by associated, Jul 23, 2010.
  1. associated
    Jun 28, 2010
    Hi All,
    THis is all new to me, so im not to sure how to go about explaining this or what the terminlogy is.
    What have is a server running Server 2003, 3cx version 8 and a Linksys SPA942 (capable of running 4 lines). Looks like its all configured as i can make and recieve calls ok.
    What i have (and this is the part im struggling to explain), on the SPA942, on the top right hand side, there are 4 buttons that light up with active lines.
    Under ports/Trunks Status in 3cx, it says i have 3 virtual extension numbers 10000, 10001, 10002, and all are registered (idle).
    I guess my question is, if i have 3 registered lines, why arnt the 3 line lights lighting up?
    Thank you in advance :)
    Trevor
    11,116
    329
    These are trunks, not extensions, they are the "links" to either a PSTN Gateway or VoIP provider.
    These are extensions or lines, registered with 3CX, they will have numbers like 102, 201, etc (if you chose 3 digit extensions). You have to datafill those in 3CX and in the Linksys.
