3CX - SSO (AD) integration
Discussion in '3CX Phone System - General' started by e23cx, Sep 5, 2017.
  1. e23cx
    Sep 2, 2017
    8
    Hi Community I'm running 3cx ver.15.
    I can't find any option to create SSO with my ActiveDirectory.
    I want users to be able to login into 3CX using their AD credentials.
    Is it possible? On the internet I could find only a 3rd party providers (onelogin.com) who does it, but I believe 3CX should have native tools to support SSO. (i.e. FreePBX supports AD - SSO integration)
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,251
    202
