3CX status via command line
Discussion in '3CX Phone System - General' started by dware, Dec 27, 2011.
  1. dware
    Sep 28, 2010
    Is it possible to change the status of an extension via the command line?
  2. roycruse
    Apr 23, 2010
    8
    Yes... as long as you can do an http get from the command line then you can use these api calls to enable and disable the extension and do some other stuff also.
    http://www.3cx.com/blog/docs/3cx-http-api/
