3cx Stun Server down or something wrong on my side ?
Discussion in '3CX Phone System - General' started by silentfun, Jun 26, 2008.
  1. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Is there anyone else with this message ?
    13:52:30.937 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.178.210:5070
    13:52:29.421 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.178.210:5070
    13:52:29.125 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.178.210:5070
    13:52:27.937 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.178.210:5070
    13:52:26.390 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.178.210:5070
    13:52:26.093 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.178.210:5070
    13:52:24.937 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.178.210:5070
    13:52:23.328 StunClient::eek:nTestTout [CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.178.210:5070
    I have this since 13:15 german time
    Andy
  2. radelman
    Feb 21, 2008
    60
    You can:
    - check the speed of your internet connection, if it is too slow, the response from the stun request will not be received in time and produce the timeout error you are receiving.
    - try other stun servers to see if you are getting the same result
    What version of 3cx are you using? Is this a new problem or has this been the case from the beginning? Do you have a dynamic ip or static ip?
  3. alsoft
    Jun 27, 2008
    35
    you need to test if your router have a QoS system enabled and if it is configurated properly. How many connections your router support? Are you doing p2p when you use 3CX?
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    I think it's port issue
    turn off the router and turn it on again
    check the port routing
    try with another router
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    hi thanks for all response
    reboot router switches and at least i restart the 3cx services and the prob was solved
    i use lates version
    and atm there are sometimes a single stun failture but no longer one entry every some seconds
    so thanks again
    Andy
  6. alsoft
    Jun 27, 2008
    35
    Do you know if your provider share a nat connection?
