3CX Supplied FQDN
Discussion in '3CX Phone System - General' started by sunkiddance, Jul 19, 2016.
  1. sunkiddance
    Jul 12, 2016
    22
    I have now received the licence for my paid version of V15.
    I have uninstalled the free version.
    Trying to install V15 using my paid key - when it wants the FQDN I have a problem:
    a) If I use the one supplied by 3CX (we have a dynamic IP address) then it asks me where to find the certificate (I have not a clue)
    b) If I tell it to give me a new one it tells me the name is already in use.
    So how do I use the FQDN already generated with the correct IP details etc. (I don't really want to use a different one)
    Terence
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  3. sunkiddance
    Jul 12, 2016
    22
    Ah - thank you for the reply.
    I see that basically it can not be done and I will have to choose a different FQDN
    Oh well, such is life :)
    Terence
