- Joined
- Mar 19, 2009
- Messages
- 14
- Reaction score
- 1
Recently upgraded the license on an install from standard to pro (using the same 3cx FQDN).
Had to restart the (Debian) server to make sure all new features became enabled, but otherwise all good.
However since upgrade I'm getting errors re the SSL can't renew. This is a 3cx supplied let's encrypt SSL.
The error I'm getting is:
Event Notification Manager ID: 50011
SSL Certificate renewal has been failed. Error: IpUpdater.FqdnGenerationException: Can not create FQDN in 600 seconds at PostInstall.CertificateHelper.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, CloudServerStatus statuses, Int32 regenerateCertificateExiredInDays, String appBin, UInt16 sipPort, UInt16 tunnelPort) at PostInstall.CertificateHelper.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
I've checked the server can connect to activation.3cx.com and letsencrypt.org without any issues.
It's been running fine up until license upgrade (although possible this could be a coincidence)
Server is locally installed Hyper V server.
Any thoughts?
Dave.
Any thoughts?
Dave.
