3CX support for Quintum Tenor
Discussion in '3CX Phone System - General' started by mwhittard, Sep 8, 2008.
  1. mwhittard
    Sep 8, 2008
    New to 3CX software and wish to know if Quintum Tenor AS boxes are supported.
    Matthew
  2. ktikoft
    Jun 22, 2007
    59
    No
    But they do work "charlief" has spent the past week getting the settings in a AS400 right. The 3cx settinsg are fairly straing forward. I have been running a DX series unit for over a year now.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    309
    There is no configuration guide for Quintum, nor are we able to support you in the configuration. However as ktikoft mentioned, we have numerous customers running Quintum Tenor succesfully with 3CX.
