3CX support TrueCNAM API lookups to allow SPAM screening
Discussion in 'Ideas' started by dcheng@cerebros.com, May 4, 2017.
3CX support TrueCNAM API lookups to allow SPAM screening 5 5 6votes
5/5, 6 votes
  1. dcheng@cerebros.com
    Aug 31, 2016
    TrueCNAM is a free service with API access that allows CNAM lookups and Caller Reputation lookups.
    https://www.truecnam.com/developers_api
    Ideally, 3cx could allow incoming calls to be screened through True CNAM. If a caller's reputation is sufficiently bad, either block the call or pass it to an IVR prompt that forces the caller to hit a random number or otherwise
    prove they are human. Callcentric offers this on their trunks, and it's been very helpful. I would love to see this integrated into 3cx. It would be a compelling feature.
    Arne Bolen likes this.
  2. Jeremy Nelson
    May 12, 2017
    16
    External CNAM lookups in general would be nice. Some providers charge a high rate (per DID) to include this information, and if we could have the phone system do a "dip" only when it's not in the 3CX phonebook, we could cut out a lot of unnecessary cost.
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    790
    134
    You could do this with a Call Flow Designer (CFD) application. Simply send all inbound calls to the CFD, have the CFD perform the lookup, and forward the call accordingly. The only concern would be the amount of time required to perform the lookup. If the lookup is slow, the caller might experience some dead-air while the lookup is being performed. We could set a maximum timeout for the lookup and cancel the lookup if it took too long. Doesn't sound hard from where I sit.
    craigreilly likes this.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    I need to look into this further - our spammy calls are increasing.
