3CX supported PRI E1 Gateways
Discussion in '3CX Phone System - General' started by rsaxe17, Feb 29, 2016.
  1. rsaxe17
    Jan 31, 2016
    16
    Hi Members,
    Are there any other supported PRI gateways, other than Patton ?
    Thanks,
    11,086
    326
    There is "officially" supported http://www.3cx.com/voip-gateways/ meaning they have been tested to work properly and support is available, and there are gateways that will no doubt work, but you will have to configure yourself. It all depends on how much time and effort you are willing to put into it. A number of forum members may have suggestions that do work for them.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Dinstar (http://www.dinstar.com) are inexpensive ones and working, not so difficult to configure manually (much easier than Patton).
