- Joined
- Aug 1, 2017
- Messages
- 8
- Reaction score
- 0
I've setup openVPN on an existing 3cx install to connect to an Asterisk instance that is providing a SIP trunk to replace an old PRI. this configuration works fine for outbound calls, but inbound calls run into issues w/ RTP not reaching the LAN IP on the interface.
09-Oct-2017 15:41:06.390 Leg L:62.2[Extn:230] is terminated: Cause: BYE from 172.18.253.121:3072
09-Oct-2017 15:41:01.807 Currently active calls - 1: [62]
09-Oct-2017 15:40:38.058 [MS105000] C:61.1: No RTP packets were received:remoteAddr=10.8.0.1:14074,extAddr=0.0.0.0:0,localAddr=172.18.253.10:10256
09-Oct-2017 15:40:36.610 Leg L:61.1[Line:10000<<4125555555] is terminated: Cause: BYE from PBX
the VPN IPs are 10.8.0.1 (asterisk) / 10.8.0.6 (3cx)
(inbound number has been anonymized in the logs)
Can I make 3cx listen on both interfaces?
