3CX System on Hosted server
meshad
Posible to run on hosted server?
If you mean a dedicated server or a virtual private server in a Datacentre then yes. I've being doing this for about 5 months now.
There are advantages and disadvantages to this
1. Multiple high speed connections to the internet
2. No NAT on the hosted machine
3. Server in a secure location
4. Great for clients with multiple locations
Disadvantages
1. No fall back to PSTN directly albeit you can possibly set this with your voip provider for call delivery (incoming)
2. No easy access directly to the hardware, everything done remotely
3. Make the integration with skype more difficult as often these computers do not have or support sound devices.
There will be other factors as well but I add these here to encourage further thought
Jonathan Hamon
Thank you for your clear information.
Now I believe, it is not possible to run 3CX without access to windows in any how
What are advantages of PSTN or GSM gateway direct to 3CX? Can we use indirect?
Dear tpinnovations
Oops its posible. i dint know that
Thank you
i have chked your links. might be consider this
Yes it can be done & we have been doing it sence V3.1 for
two year now. We have 3cx servers in two data centers.
(sipero quote) There are advantages and disadvantages to this
4. Great for clients with multiple locations (great for clients as a whole)
Disadvantages (depends on your client)
2. No easy access directly to the hardware, everything done remotely (don't allways need direct access)
3. Make the integration with skype more difficult as often these computers do not have or support sound devices. (this will change)
ecwilson
1. If you setup VPN you can integrate a PSTN line into the system. You may have some voice delay but it will work.
2. If you purchase a dedicated server, or a hosted solution, you don't need to worry about hardware.
3. I wouldn't recommend Skype as a primary provider, It just screams bad news.
Get 3CX - Absolutely Free!
3CX
