3cx system version 14
Discussion in '3CX Phone System - General' started by csp, Aug 4, 2015.
  1. csp
    csp
    Apr 24, 2015
    14
    Hello everyone ,
    I have some questions .
    I recently downloaded and install the virtual PBX server version 14 for multiple instances .
    Im running a windows server 2012 R2 standard. When i the pbx was installing the option of abyss server wasn't enable so by default it install the IIS. But in IIS i think i cant change the ports. The problem is that i have some other devices in my network that has this ports and port forwarded with the specific puplic ip that i have.
    Does it need an extra public ip , especially for the PBX server to run the IIS in the ports 80&443 ?
    And also when it ask me for a domain name i but the domain name of the server that i have. Does it need to have a register domain name in go daddy for example to be able to access for an external network ?
    ex. My domain name of the server is CSPcloud.local
    I'm waiting for a reply
    Thank you
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Yes in v14 RC the web ports can be customized only in Abyss not in IIS.
    If already have services running on 80/443 then reinstall with Abyss and choose custom ports or use another public IP with IIS 80/443.
    Please review documentation available in admin manual :
    Section 7 – 3CX Phone System Virtual PBX Server (v14)
    Introduction & Licensing
    Installing 3CX Phone System Virtual PBX Server
    Creating Virtual PBX Instances
    Configuring a Virtual PBX Instance
    Deploying a Virtual PBX Configuration to a Customer
    Backup and Restore of Virtual PBX instances
