3CX Tapi Driver crashing
Discussion in '3CX Phone System - General' started by Tifoso, Jan 17, 2018.
  1. Tifoso
    Oct 17, 2017
    57
    9
    Hi 3CX Support,
    if I install the 3CX TAPI driver on a terminal server the phone and modem service is crashing. The TAPI driver isn't working. Somebody has experience with 3CX TAPI drivers on Windows Terminal Servers?
    I cant also not open the configuration/settings in the system settings:
    BR Tifoso
  2. ivank
    3CX Support
    Jan 4, 2017
    54
    5
    Hi! Could you provide remote access to the machine, please?
  3. Tifoso
    Oct 17, 2017
    57
    9
    is a customer pc and i cant give you access. do you have any idea for the problem?
  4. ivank
    3CX Support
    Jan 4, 2017
    54
    5
    Try setting REG_DWORD parameter TSPLogEnabled to 1 in the registry key
    HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\3CX\3CXPhone for Windows
    Then try to access Phone and Modem in the control panel.
    Please, locate and provide the following files (via PM if they contain private info):
    1. "c:\ProgramData\3CXPhone for Windows\Logs\3CXTapiSP.log".
    2. %temp%\3CXPlugins_install.log
    3. c:\ProgramData\3CXMultiLineTapi\3CXTAPI.ini
    #4 ivank, Jan 17, 2018
