3CX TAPI Driver
Discussion in '3CX Phone System - General' started by Erling Computer, Feb 6, 2010.
  1. Erling Computer
    Feb 3, 2010
    7
    Anybody using this (other than for Outlook)?
    I'm hoping that if it's loaded as the default TAPI driver in Windows, 3rd party apps can have their TAPI call requests routed to the PBX, and initiate phone calls.
    Any thoughts?
    Thanks in advance.
    Murray Messelt
    Erling Computer Solutions
    Austin, TX
  2. mikeyg
    Feb 8, 2010
    I am new to 3cx and have just down loaded and installed the free version along with 3cx assistant.
    I cannot understand what the 3CX assistant does with the free version as nothing seems to register and the TAPI drive does not dial or connect either to the local extension or to the end (outbound) number.
    Have I missed something or is this right - i.e I cannot use the 3CX features or the TAPI driver?
    I have also tried to connect a third party SIP TAPI drive but also having problems here. IS there a TAPI driver that will work with outlook, ACT! and 3CX.
    I do hope some one can help a complete newbie and IT novice.
    Thank you in advance
  3. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    The free version is just to show what the assistant can do.
    nothing is enabled in the free version. The extensions might be registered in reality but the assistant will just show everything grey and unregistered. this is expected.
    Use a demo key to see what you are missing :)
  4. mikeyg
    Feb 8, 2010
    Can you provide or if not how do I get one.
    Thank you.
    Regards
    Michael
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,005
    308
    To get outbound TAPI and Assistant functionality you need to purchase a commercial edition.
