3CX TAPI on multiple lines
Discussion in '3CX Phone System - General' started by it2pimp, Dec 14, 2012.
  1. it2pimp
    May 19, 2011
    26
    Is it possible to use TAPI for all lines on the server where 3CX is installed ?
    It works only for one extension if I install the desktop components for 3CX Myphone when logged in.
  2. darthzejdr
    Feb 20, 2012
    17
    I don't think this is possible, but unless your application requires tapi you should be able to create calls via api's.
