3CX TAPI on v12
Discussion in 'Windows' started by fpernice, Oct 3, 2013.
  1. fpernice
    Sep 6, 2013
    8
    Previously we had with 3CX Assistant, 3CX TAPI Service Provider installed.
    With the new 3CXPhone under v12, where can I find the 3CX TAPI Service Provider ?
    Regards,
    François
  2. rogueblackburn
    Aug 11, 2013
    42
    If you are looking for the Outlook integration, download the CRM Module, run it, then choose the Outlook plugin. I don't think there is a 3rd party TAPI avaible at the moment.
  3. fpernice
    Sep 6, 2013
    8
    Thank's, but it's not for outlook integration but for our own softwware ...
  4. nickjhunt
    Apr 25, 2013
    42
    download the CRM package and there is a tick box for Tapi
  5. fpernice
    Sep 6, 2013
    8
    thank's !
