3CX Tel: URL protocol
Discussion in 'Windows' started by joemailey, Jun 30, 2014.
  1. joemailey
    Jan 3, 2014
    25
    Just wondering if this works with the standard version of 3CX 12? or does it require me to use the pro version?
    AsI currently use the standard version and the 3cx phone app doesn't pass the url to dial the number.
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Nope. I don't think they have implemented a tel: URI handler.. yet.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    51
    Did you read this article?
    http://www.3cx.com/blog/voip-howto/tel-protocol-3cxphone/
  4. joemailey
    Jan 3, 2014
    25
    Yea I read that link, but it still doesn't work.
    The call handler doesn't pass the numbers to 3cx client.
  5. complex1
    Jan 25, 2010
    832
    51
    Does the Hot Keys work?
    Maybe a reinstall of the 3CXPhone for Windows will solve the issue?
  6. joemailey
    Jan 3, 2014
    25
    It doesn't work on any machine.
    Think on the blog in the comments it mentioned it uses the API which is only able on the Pro version, I was hoping someone could confirm that for me.
  7. joemailey
    Jan 3, 2014
    25
  8. complex1
    Jan 25, 2010
    832
    51
    I think you are quite right.
    It only runs if you have the Pro version.
  9. MariosS_3CX
    May 26, 2014
    12
    We confirm that the license has to be PRO license.
    The Tel protocol uses the calltriggercmd plugin therefore it uses the 3CXPhone API which is only available in the professional edition of our 3CX Phone System.
  10. joemailey
    Jan 3, 2014
    25
    Thanks for the update, you might want to make that clear in this blog post http://www.3cx.com/blog/voip-howto/tel-protocol-3cxphone/
  11. MariosS_3CX
    May 26, 2014
    12
    Thank you for your feedback, i will forward this request to the appropriate department.
