- Joined
- Oct 11, 2014
- Messages
- 2
- Reaction score
- 0
I have a remote office connecting in to my main 3CX office, the remote office uses a legacy Asterisk system (nextix) and I'm having trouble getting them to connect.
I have a master bridge in 3CX and I created a tunnel on the Asterisk system (config as in image) which works fine, 3cx sees the bridge as up and I can call 3cx -> remote however remote ->3cx gets a no circuits available message.
Checking the logs I see this error:
This shows the connection isn't working but 3cx isn't accepting the connection for some reason, the password and username are correct, (12345 for testing) however I can't make calls to the main office.
Any help would be much appreciated!
[CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE [email protected] tid=68a7a2ce cseq=INVITE [email protected] / 103 from(wire)
[CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
