3CX to CCME
Discussion in '3CX Phone System - General' started by nibbles1966, Oct 21, 2007.
  1. nibbles1966
    Oct 21, 2007
    I've got a voip lab at home with a Cisco Call Manager Express and I've just downloaded 3CX. I've got a couple of phones registered via Skinny to the call manager. I've also got a couple of SIP phones registered to the 3CX box. The problem I've got is to get the call manager and the 3CX to pass calls to each other. I've configured a dial peer using sip on the call manager but I get nothing. They can ping each other no problem so its not a connectivity issue. The phones can call to each other on the same device so they are registering ok as far as I can tell.
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    Hallo friend,
    I have tried the same, but it is not possible in the version 3.1 of 3CX to make SIP trunking between CCME and 3CX.
    They say it will be possible in version 4.o to make SIP trunking between 3CX and 3CX system and not yet sure about trunking with other proprietary SIP Servers like CME in this case.
    regards,
