3CX trunk to Cisco Unified Communications Manager (CUCM)
Discussion in '3CX Phone System - General' started by wrup, Jul 30, 2009.
  1. wrup
    Jul 30, 2009
    Hi, new to the board and to 3CX. Very nice package and look forward to learning more.
    Currently I'm evaluating 3CX (7.1 free version) and since I've been a long time network engineer using Cisco products, I'm looking for some guidance and configuration examples for setting up a SIP trunk between the 3CX system and a Cisco Call Manager so that calls can be passed back and forth to Cisco gateways and phones registered to the Call Manager. If it is possible, are there specific versions of Call Manager that you must have (4.2 preferably). Do you have any configuration examples to assist?
    Further, is it possible to set up the same between a 3CX system and a Call Manager Express system?
    Thanks in advance!!!
  2. comresource
    comresource Member
    May 22, 2009
    303
    Yes you can create a SIP trunk between 3CX and Cisco. Here is a forum thread showing more details
    http://www.3cx.com/forums/3cx-to-cme-6914.html
  3. wrup
    Jul 30, 2009
    thanks. i'll give it a try in the lab.
    anything on CUCM (Call Manager)?
  4. wrup
    Jul 30, 2009
    OK, looks like i have the SIP trunk up and running to the Cisco CUCME (3845 w/PRI to PSTN). However, when I attempt to dial an external phone number on the PSTN, from a 3CX registered phone using the PRI that is attached to the 3845 CUCME, the dial-peer hunt fails. If I dial from a phone registered to the CUCME, the call succeeds. Here's the logs from the 3CX and debug from the router. Can anyone tell me what I'm missing?
    3CX log:
    07:19:00.343 [CM503008]: Call(11): Call is terminated
    07:19:00.343 [CM503015]: Call(11): Attempt to reach <sip:96784855173@172.16.28.6> failed. Reason: Not Implemented
    07:19:00.343 [CM503003]: Call(11): Call to sip:6784855173@172.16.28.1:5060 has failed; Cause: 488 Not Acceptable Media; from IP:172.16.28.1:5060
    07:19:00.265 [CM503024]: Call(11): Calling VoIPline:6784855173@(Ln.10000@3845 CME)@[Dev:sip:10006@172.16.28.1:5060]
    07:19:00.265 [CM503004]: Call(11): Route 1: VoIPline:6784855173@(Ln.10000@3845 CME)@[Dev:sip:10006@172.16.28.1:5060]
    07:19:00.250 [CM503010]: Making route(s) to <sip:96784855173@172.16.28.6>
    07:19:00.250 [CM505001]: Ext.1000: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7960G/8.0] Transport: [sip:172.16.28.6:5060]
    07:19:00.250 [CM503001]: Call(11): Incoming call from Ext.1000 to <sip:96784855173@172.16.28.6>
    CUCME Debug:
    Jul 31 07:41:22.442: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
    Calling Number=6784855173, Called Number=6784855173, Peer Info Type=DIALPEER_INFO_SPEECH
    Match Rule=DP_MATCH_DEST; Called Number=6784855173
    No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
    Jul 31 07:41:22.442: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
    Result=NO_MATCH(-1)
    Jul 31 07:41:22.442: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
    Calling Number=10006, Called Number=, Voice-Interface=0x0,
    Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
    Result=NO_MATCH(-1) After All Match Rules Attempt
    Jul 31 07:41:22.446: //-1/E7C0902B81DA/DPM/dpAssociateIncomingPeerCore:
    Calling Number=10006, Called Number=6784855173, Voice-Interface=0x0,
    Jul 31 07:41:22.446: //-1/E7C0902B81DA/DPM/dpAssociateIncomingPeerSPI:
    System default peer Tag=9983, Result=0
