3cx trunk to trunk (aster`s call)
Discussion in '3CX Phone System - General' started by vpaulo, Dec 1, 2015.
  1. vpaulo
    Jun 24, 2009
    23
    Hi colleagues!
    I use 3CX minimum over 10 years. Well, how many it is possible??? When you return normal functions of calls between trunks? And trust beetwen trunk to trunks call??
    Well again, why should I remember an asterisk and to realize everything on it. You lose so many clients.
    Why CEO Nick Galea can't persuade to be returned this functionality. Technical specialists know about what I speak. If you don't need sales, clients and successful implementation of projects aren't necessary???
    IMHO, Блиять продайте уже 3CX, and bury him behind a wall, and We`ll go back to an asterisk, cisco and other products.
    Paul.
    11,105
    329
    I'm sorry...I don't understand what you are actually complaining about. You need to provide some additional details.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    If you don't like it don't buy it.
  4. vpaulo
    Jun 24, 2009
    23
    see att.
    I don`t ask you about what I need to buy.
  5. leejor
    11,105
    329
    So...what type of trunk (3CX settings) is being used to access the GSM network? Is it a trunk to a GSM gateway?
  6. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Can you configure trunk to gsm provider how Bridge ?
  7. vpaulo
    Jun 24, 2009
    23
    Simple sip trunk without autorization. LIke sip provider. It`s not GW.
    what you mean?? bridge. In the GSM operator (next side sip-to-sip trunk) they`ve private software platform. It`s not 3cx. So, how can I switch this trunk in bridge mode??
    paul
  8. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Trunk - to - trunk call across the bridge work .
    you can setup 3CX how master and receive registration , than your custom application send registration .
    For caller-id you can manipulate more field how-to send Caller-id
    Without bridge It is possibile work around for few your question :
    point 2- Incoming 499 from provider : than you can create a dummy extension 1499 with call forward to 499 , you manage incoming DDI 499 to 1499 and it's work .
    point 6 - need Bridge connection
  9. vpaulo
    Jun 24, 2009
    23
    ok. How? bridge in 3cx we can create only with another 3cx. In my case, the second part is operator`s soft switch.
    maybe, but when user press "499" while incoming call from voip prov, system say - not found.
    HOW?
  10. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi VPaulo , were you able to connect asterisk with 3cx via bridge, I made one today...
