3CX trunk - with Avaya IP Office 500 V2
Discussion in '3CX Phone System - General' started by F Kalpana, Feb 12, 2018.
Tags:
  1. F Kalpana
    Dec 21, 2017
    Avaya License requirement :
    1- IP Office essential edition
    2- SIP Trunk license ( to trunk with 3CX )
    3- PRI/SIP Channel license ( Trunk to your ISP with either SIP or PRI )
    AVAYA IP500 V2 IP : 192.168.8.42
    Port : LAN2 (Here I used LAN2 and LAN1 is not using and not connected on N/W)
    Proto:UDP
    Port:5060
    Codecs allowed :G711Ulaw
    ISP PRI Trunk : XXXXX900-XXXX999 3CX IP : 192.168.8.241 Proto:UDP Port:5060 Codecs allowed :G711Ulaw Extension : 1XX Queues : 8XX
    3CX Configurations
    1)Create One SIP trunk in 3CX to Avaya .
    SIP Trunk in New Trunk Generic SIP Trunk , 3cx by giving peer IP, No authentication
    Screenshots and more details we have uploaded here . https://www.claudion.com/3cx-trunk-avaya-ip-office-500-v2/
    Document prepared by @arafath
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,400
    186
