3CX trunk with CME
Discussion in '3CX Phone System - General' started by iramku, May 3, 2012.
  1. iramku
    May 3, 2012
    Hello All,
    I am currently trying to create a sip trunk between Call Manager Express and 3CX Phone System.
    I have setup the dial-peer in CME, and the trunk without authentication and an outbound rule in 3CX.
    When i try to make a call from CME to 3CX or on the other way i get a message 488:Unsupported media type.
    I think it is a codex issue. ( I have experienced the same problem when i tried to register 3CX softphone to CME, this problem was fixed by changing the codex to g711ulaw). Does anyone have any configuration template for this?
    Thanks in advance,
    Ibrahim
  2. iramku
    May 3, 2012
    I managed to send calls from CME to 3CX. Any idea for 3CX->CME?
  3. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Do you have the logs from the failed call from 3cx to cme? G711 Ulaw should work.
