3CX-Tunnel and Codec 729
Discussion in 'Android' started by fas, Jul 8, 2010.
  1. fas
    fas
    Mar 9, 2009
    6
    Do you plan to support the 3CX-Tunnel as well? I often have problems to connect my licenced 3CX-PBX do to firewalls. If yes, do you have any roadmap?
    Is there any possibility to get your 3CX Phone with Codec 729 available (for licenced clients like me)?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,578
    115
    The tunnel is something we are planning to do for a future release of the 3CX Phone for Android, there is currently no ETA on this.
    As for the G729 codec, this is also something we are planning to add for the new Android release that supports paypal payments. The user will be able to buy a license for the G729 codec that the user will be able to use for their Android Phone.
    - This also has no ETA as we are currently still working on Ironing out the most basic issues that users have with their Android Phones. Once that is done, new features will come along.
