3cx Tunnel and Myphone
Discussion in '3CX Phone System - General' started by mhnichols, May 16, 2011.
  1. mhnichols
    May 22, 2009
    11
    Am I missing something?
    How do you set the new 3CX Myphone to work through the 3CX tunnel??
  2. FBW
    FBW New Member
    Nov 19, 2008
    108
    I was wondering the exact same thing.
    Unless of course it's being pushed through the new phone provisioning in the management console...
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I dont believe it works through the tunnel, as a Silverlight app I am assuming it works over the http port.
  4. mhnichols
    May 22, 2009
    11
    Which would be fine if you had the ports open/forwarded.
    But we have the system locked down to use the tunnel only, (one of the great features of 3CX) so now unable to use the new Assistant/Myphone.
    Don't really want to start opening more firewall ports than absolutely needed.
    Why remove support for the tunnel in the assistant? is this now going to be obsolete? looks like another good feature being removed!
  5. KerryG
    Jun 19, 2009
    960
    MyPhone is a huge change from the Assistant architecture and while I personally wish we had kept the Assistant functionality while MyPhone was being developed and perfected, that was not 3CX's decision. At this point, for this and other reasons, not everyone is going to be able to upgrade to v10 just yet. MyPhone has to mature a little and it will get there fairly soon I suspect.
  6. jcasares
    Dec 5, 2009
    92
    Ops, a feature I used and now can't. With every hour I find more missing things. :(
  7. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi guys - you have still have the functionality to connect locally and remotely without installing nothing. Hey guys this is something big in my opinion.
    Also we provide Out of browser so if a users want to continue working at home - they can do whatever they want.
    You can connect your 3cx phone or use a remote extension and accept calls- change status - change your forwarding rules anytime you want.
    There is a'lot of features/Improvement that before in version 9 you did not use to have.
    Also what about Play Vmails - Play by phone and etc. Call History, seeing other extensions statuses, notifications of missed calls and even vmails too.
    What about Prefix and so on.
    BTW new features are coming soon!!
  8. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Michael,
    I'm reading your reply and wondering if you are saying there is a way to configure and use MyPhone remotely? If so, I've not discovered a way to do that and wonder if you might elaborate, please!.
  9. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Oh, right, opening port 5000 is open then it works. I'm not sure what kind of security issue that may bring though. It *is* a website ;-).
