3CX tunnel loosing connection
Discussion in 'iOS' started by dlazure, Jan 13, 2013.
  1. dlazure
    Nov 5, 2012
    65
    ok i know this is a known issue but i am wondering if it is suposed to be fixed at this moment ?
    i am experiencing connection lost all the time with my iphone and i need to reconnect it manally each time.
    iphone ios 6.1 and the latest free version of 3CX
    thanks
  2. StefanW
    Jun 2, 2009
    1,222
    93
    please use the search function, you will find the answer covered several times
