3cx tunnel, presence status without port 443/80
Discussion in 'Ideas' started by vitaminc, Feb 1, 2016.
  1. vitaminc
    Feb 1, 2016
    18
    7
    If we use the 3cx tunnel (port: 5090) we are able to phone, but unfortunately the softphone is not registering and does not show any presence status because of the closed ports 443/80 from public internet. Why not use also port 5090 for presence status when public ip is used?
    We do not like the idea to open 443 to the public internet, and using VPN all the time is quite oldskool.
  2. macfusion
    Aug 4, 2015
    5
    As SBC is becoming a critical component of 3CX cloud and security is paramount all 3CX related date should flow though the tunnel including (but not limited to) http, https, phone firmware upgrades. Dave
