3CX Tunnel / Session Border Controller
Discussion in '3CX Phone System - General' started by Steve Takacs, Jul 17, 2017.
  1. Steve Takacs
    Jul 17, 2017
    Hi Guys,
    My 3cxsbclog is full with errors.
    I did some research but I can`f find the meaning / cause.
    Does someone know why I see these errors?
    What does it mean? What can I do to stop these errors?
    ERR | 20170717-090533.070 | 3CXTunnel | TUNL | 6660 | Bridge.cpp:718 | Has no registered RTP session for local destination 10.120.5.13:11790
    ERR | 20170717-090533.092 | 3CXTunnel | TUNL | 6660 | Bridge.cpp:718 | Has no registered RTP session for local destination 10.120.5.13:11790
    ERR | 20170717-090542.853 | 3CXTunnel | TUNL | 10460 | Rtp.cpp:143 | Error reading from RTP socket 416, {RS:59744}: error 10054
    ERR | 20170717-090548.072 | 3CXTunnel | TUNL | 6660 | Bridge.cpp:718 | Has no registered RTP session for local destination 10.120.5.23:11786
    ERR | 20170717-090548.093 | 3CXTunnel | TUNL | 6660 | Bridge.cpp:718 | Has no registered RTP session for local destination 10.120.5.23:11786
    ERR | 20170717-090550.576 | 3CXTunnel | TUNL | 6660 | Bridge.cpp:718 | Has no registered RTP session for local destination 10.120.5.13:11794
    ERR | 20170717-090556.164 | 3CXTunnel | TUNL | 6660 | Bridge.cpp:718 | Has no registered RTP session for local destination 10.120.5.13:11794
    ERR | 20170717-090605.426 | 3CXTunnel | TUNL | 10460 | Rtp.cpp:143 | Error reading from RTP socket 416, {RS:59744}: error 10054
    ERR | 20170717-090605.446 | 3CXTunnel | TUNL | 10460 | Rtp.cpp:143 | Error reading from RTP socket 416, {RS:59744}: error 10054
    ERR | 20170717-090605.467 | 3CXTunnel | TUNL | 10460 | Rtp.cpp:143 | Error reading from RTP socket 416, {RS:59744}: error 10054
    ERR | 20170717-090605.508 | 3CXTunnel | TUNL | 10460 | Rtp.cpp:143 | Error reading from RTP socket 416, {RS:59744}: error 10054
    ERR | 20170717-090605.546 | 3CXTunnel | TUNL | 10460 | Rtp.cpp:143 | Error reading from RTP socket 416, {RS:59744}: error 10054
  2. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    170
    58
    THere are two reasons you might see this:
    1. You have ring groups and at times two people will pick up at the almost same time. This error happens for the person who was a few milliseconds late and got dead air - no audio. So - its an annoyance but not a problem.
    2. Your firewall is blocking RTP ports.
    Best,
    Kirk
  3. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Steve,
    I have sent you a P.M, please check your inbox.
  4. herbst
    Nov 20, 2009
    7
    We have same error:
    Name=3CXSBC15.5.1136.6
    ERR | 20170912-140655.825 | 3CXTunnel | TUNL | 5660 | Bridge.cpp:718 | Has no registered RTP session for local destination
    Our problem: lost sound after 30 or 60 seconds. After 10s sound return.
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Hi herbst,
    Please check your inbox, I have sent you a P.M
  6. PreHack
    Jun 20, 2017
    I have the same problem, please help
    Code:
    ERR | 20170918-205738.474 | 3CXTunnel | TUNL | 4920 | TunnelTcp.cpp:262 | Bridge [3CXSBC15.5.2607.1] failure 'Too long inactivity' on TCP connection: while processing tunnel connection
    ALERT | 20170918-205738.505 | 3CXTunnel | TUNL | 4920 | TunnelTcp.cpp:660 | Sending first packet from [ V4 0.0.0.0:51331 UNKNOWN_TRANSPORT ] to [ V4 80.254.xxx.xxx:5090 TCP ]
    ALERT | 20170918-205838.660 | 3CXTunnel | TUNL | 2572 | TunnelTcp.cpp:660 | Sending first packet from [ V4 0.0.0.0:51335 UNKNOWN_TRANSPORT ] to [ V4 80.254.xxx.xxx:5090 TCP ]
    ERR | 20170918-192648.546 | 3CXTunnel | TUNL | 2572 | Bridge.cpp:718 | Has no registered RTP session for local destination 192.168.10.7:12058
    ERR | 20170918-192705.218 | 3CXTunnel | TUNL | 2572 | Bridge.cpp:718 | Has no registered RTP session for local destination 192.168.10.7:12066
    ERR | 20170918-192705.233 | 3CXTunnel | TUNL | 2572 | Bridge.cpp:718 | Has no registered RTP session for local destination 192.168.10.7:12066
    ERR | 20170918-192842.811 | 3CXTunnel | TUNL | 2572 | Bridge.cpp:718 | Has no registered RTP session for local destination 192.168.10.7:12066
    ERR | 20170918-192851.421 | 3CXTunnel | TUNL | 2572 | Bridge.cpp:718 | Has no registered RTP session for local destination 192.168.10.7:12078
    ERR | 20170918-192851.452 | 3CXTunnel | TUNL | 2572 | Bridge.cpp:718 | Has no registered RTP session for local destination 192.168.10.7:12078
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @PreHack
    What version PBX are running? Is it a windows sbc or linux? Are the phones behind the SBC up to date with the recommended fimware? is this causing you a specific issue?
  8. PreHack
    Jun 20, 2017
    I'm running 3CX 15.5 on Debian and have a Windows SBC.
    My Phone is a Yealink W56P with firmware 25.80.0.15 (seems to be the latest). I have audio problems, most of the time I can't hear the other side, everything else seems to be normal.
    Update: Changed SBC to Debian, seems to work perfectly fine.
    #8 PreHack, Sep 19, 2017
  9. YiannisH_3CX
    May 10, 2016
    4,349
    274
    Glad this has worked for you and thank you for the update, keep an eye on it and let us know if you face any further issues
