3CX Tunnel
Discussion in 'iOS' started by thomassn, Jun 23, 2012.
  1. thomassn
    Jun 23, 2012
    7
    Im trying to get my 3CX Tunnel working to get my iPad connect via 3G to my 3CX server.
    I have made following nat on my router and enabled SIP ALG (got a Linksys E3000)
    However the 3CX Tunnel keep trying to connect but it cant connect. What have I done wrong ? The 3CX iPhone app worked out fine by WiFi
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    763
    39
    Remove in your route “3CX Intern 7000-7499” and add “3CX Tunnel 5090-5090”
    Also Disable SIP ALG.
  3. thomassn
    Jun 23, 2012
    7
    Done as you wrote. Thx the answer even on a saturday :p However it didnt help me.
    My 3CX Tunnel settings at my iPad: attachment 1
    3CX Tunnel settings at Management Interface: attachment 2
    #3 thomassn, Jun 23, 2012
  4. thomassn
    Jun 23, 2012
    7
    Oh I just saw the post about posting topics :)
    My iPad is a iPad2 3G+WiFI 32GB with 5.1.1 iOS and not jailbreaked!
    My Router is a Linksys E3000
    My server is installed on Windows Server 2008 R2 with SP1 in a VMware Workstation. The network card in the virtual machine is set to Bridge Mode and gets the IP-address from the DHCP-server in the Linksys E3000
  5. complex1
    Jan 25, 2010
    763
    39
    Have you run the firewall checker without any errors?
    For security reasons, please use a more secure password for your tunnel.
    It is not recommended to use a dynamic address for your 3cx server, please use a static one.
  6. thomassn
    Jun 23, 2012
    7
    Code:
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <10:33:08>: Phase 1, checking servers connection, please wait...
    <10:33:08>: Stun Checker service is reachable. Phase 1 check passed.
    <10:33:08>: Phase 2a,  Check Port Forwarding to UDP SIP port, please wait...
    <10:33:13>: UDP SIP Port is set to 5060. Response received correctly with no translation. Phase 2a check passed.
    <10:33:13>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
    <10:33:18>: TCP SIP Port is set to 5060. Response received correctly with no translation. Phase 2b check passed.
    <10:33:18>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
    <10:33:23>: TCP TUNNEL Port is set to 5090. Response received correctly with no translation. Phase 3 check passed.
    <10:33:23>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
    <10:33:34>: UDP RTP Port 9000. Response received correctly with no translation. Phase 4-01 check passed.
    <10:33:39>: UDP RTP Port 9001. Response received correctly with no translation. Phase 4-02 check passed.
    <10:33:44>: UDP RTP Port 9002. Response received correctly with no translation. Phase 4-03 check passed.
    <10:33:48>: UDP RTP Port 9003. Response received correctly with no translation. Phase 4-04 check passed.
    <10:33:53>: UDP RTP Port 9004. Response received correctly with no translation. Phase 4-05 check passed.
    <10:33:57>: UDP RTP Port 9005. Response received correctly with no translation. Phase 4-06 check passed.
    <10:34:02>: UDP RTP Port 9006. Response received correctly with no translation. Phase 4-07 check passed.
    <10:34:06>: UDP RTP Port 9007. Response received correctly with no translation. Phase 4-08 check passed.
    <10:34:11>: UDP RTP Port 9008. Response received correctly with no translation. Phase 4-09 check passed.
    <10:34:15>: UDP RTP Port 9009. Response received correctly with no translation. Phase 4-10 check passed.
    <10:34:20>: UDP RTP Port 9010. Response received correctly with no translation. Phase 4-11 check passed.
    <10:34:24>: UDP RTP Port 9011. Response received correctly with no translation. Phase 4-12 check passed.
    <10:34:29>: UDP RTP Port 9012. Response received correctly with no translation. Phase 4-13 check passed.
    <10:34:33>: UDP RTP Port 9013. Response received correctly with no translation. Phase 4-14 check passed.
    <10:34:38>: UDP RTP Port 9014. Response received correctly with no translation. Phase 4-15 check passed.
    <10:34:43>: UDP RTP Port 9015. Response received correctly with no translation. Phase 4-16 check passed.
    <10:34:47>: UDP RTP Port 9016. Response received correctly with no translation. Phase 4-17 check passed.
    <10:34:52>: UDP RTP Port 9017. Response received correctly with no translation. Phase 4-18 check passed.
    <10:34:56>: UDP RTP Port 9018. Response received correctly with no translation. Phase 4-19 check passed.
    <10:35:01>: UDP RTP Port 9019. Response received correctly with no translation. Phase 4-20 check passed.
    <10:35:05>: UDP RTP Port 9020. Response received correctly with no translation. Phase 4-21 check passed.
    <10:35:10>: UDP RTP Port 9021. Response received correctly with no translation. Phase 4-22 check passed.
    <10:35:14>: UDP RTP Port 9022. Response received correctly with no translation. Phase 4-23 check passed.
    <10:35:19>: UDP RTP Port 9023. Response received correctly with no translation. Phase 4-24 check passed.
    <10:35:23>: UDP RTP Port 9024. Response received correctly with no translation. Phase 4-25 check passed.
    <10:35:28>: UDP RTP Port 9025. Response received correctly with no translation. Phase 4-26 check passed.
    <10:35:33>: UDP RTP Port 9026. Response received correctly with no translation. Phase 4-27 check passed.
    <10:35:37>: UDP RTP Port 9027. Response received correctly with no translation. Phase 4-28 check passed.
    <10:35:42>: UDP RTP Port 9028. Response received correctly with no translation. Phase 4-29 check passed.
    <10:35:46>: UDP RTP Port 9029. Response received correctly with no translation. Phase 4-30 check passed.
    <10:35:51>: UDP RTP Port 9030. Response received correctly with no translation. Phase 4-31 check passed.
    <10:35:55>: UDP RTP Port 9031. Response received correctly with no translation. Phase 4-32 check passed.
    <10:36:00>: UDP RTP Port 9032. Response received correctly with no translation. Phase 4-33 check passed.
    <10:36:04>: UDP RTP Port 9033. Response received correctly with no translation. Phase 4-34 check passed.
    <10:36:09>: UDP RTP Port 9034. Response received correctly with no translation. Phase 4-35 check passed.
    <10:36:13>: UDP RTP Port 9035. Response received correctly with no translation. Phase 4-36 check passed.
    <10:36:18>: UDP RTP Port 9036. Response received correctly with no translation. Phase 4-37 check passed.
    <10:36:22>: UDP RTP Port 9037. Response received correctly with no translation. Phase 4-38 check passed.
    <10:36:27>: UDP RTP Port 9038. Response received correctly with no translation. Phase 4-39 check passed.
    <10:36:32>: UDP RTP Port 9039. Response received correctly with no translation. Phase 4-40 check passed.
    <10:36:36>: UDP RTP Port 9040. Response received correctly with no translation. Phase 4-41 check passed.
    <10:36:41>: UDP RTP Port 9041. Response received correctly with no translation. Phase 4-42 check passed.
    <10:36:45>: UDP RTP Port 9042. Response received correctly with no translation. Phase 4-43 check passed.
    <10:36:50>: UDP RTP Port 9043. Response received correctly with no translation. Phase 4-44 check passed.
    <10:36:54>: UDP RTP Port 9044. Response received correctly with no translation. Phase 4-45 check passed.
    <10:36:59>: UDP RTP Port 9045. Response received correctly with no translation. Phase 4-46 check passed.
    <10:37:03>: UDP RTP Port 9046. Response received correctly with no translation. Phase 4-47 check passed.
    <10:37:08>: UDP RTP Port 9047. Response received correctly with no translation. Phase 4-48 check passed.
    <10:37:12>: UDP RTP Port 9048. Response received correctly with no translation. Phase 4-49 check passed.
    <10:37:17>: UDP RTP Port 9049. Response received correctly with no translation. Phase 4-50 check passed.
    Application exit code is 0
    The 3CX is using a static address which are excluded by the DHCP server
  7. complex1
    Jan 25, 2010
    763
    39
    The result of the firewall checker looks good.
    If you are running a Anti Virus and a Firewall protection, please turn both temporarily off.
    Type on a other PC “Telnet <ip-add of 3CX server> dash 5090” and see if you get a connection with the 3CX server. It shows a few random characters, then nothing for a few seconds, then a text like “the connection is lost” or something like that.
    When I am trying to Telnet your IP (62.116.212.58), I get no response.
    If you are trying to connect your iPad via the tunnel with 3CX, do you see an attempt, in the 3CX log, to set-up the tunnel?
    Have you double-checked the tunnel password (3CX and iPad), local and remote Tunnel IP?
  8. thomassn
    Jun 23, 2012
    7
    I changed the tunnel password and it helped. The 3CX Tunnel is up and running.
    My iPad 2 reports following:
    Tunnel connected
    Request Timeout/Not registered
    Serverlog:
    12:27:14.552 [CM503016]: Call(1): Attempt to reach <sip:102@192.168.1.50:5060> failed. Reason: Not Registered
    12:27:14.552 [CM503017]: Call(1): Target is not registered: Ext.102
    I have turned on 3CXPhone Provision and I have unselected Disallow use of extension outside the LAN
  9. complex1
    Jan 25, 2010
    763
    39
    Ok, now you have a tunnel up and running, but this will not say that ext. 102 (iPad) is registered with the 3CX server.
    There is a good description how to register a iPhone/iPad with 3CX.
    Please read this first.
    http://www.3cx.com/blog/3cxphone/iphone/configuring/
  10. thomassn
    Jun 23, 2012
    7
    I followed the manual (your link) but it didnt helped.
  11. complex1
    Jan 25, 2010
    763
    39
    The PBX port must be 5060 instead of 5090
  12. thomassn
    Jun 23, 2012
    7
    Successful :D
    Thx you very much :D
  13. complex1
    Jan 25, 2010
    763
    39
    Your welcome.
    The pleasure is on my side. :D
  14. Twilio
    Jun 26, 2012
    hi,
    i think it is no difficult...... you just remove your current router 3CX intern 7000-7499 and work in 3CX 5090-5090.......
    and you should disable your SIP ALG from your application......
    it will worth .......... :)
