Solved 3CX Update Issues
Discussion in '3CX Phone System - General' started by Schrodz, Feb 15, 2018.
  1. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    We have an issue with our call center this morning. When one of the agent are in the Q. They are getting another call come through on line 2. Sometimes 3 calls at one time.
    We haven't changed any configs and on the users extension the box "Allow Multiple Calls" Is NOT ticked.
    This is causing issues and a loss of calls. I will have to roll back the update if we cant fix this!
    Dan
  2. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    How do we roll back? No response from 3cx. I also cannot raise any support requests anymore.
  3. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    You need an old backup and then uninstall and install the older version.
  4. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    I have an old backup, I just would of thought 3CX would have some kind of info, or response
  5. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Hi Schrodz,
    Since the option "Accept multiple calls" is not selected for the extension then all of the calls with destination the specific extension, while this extension is already in a call should be forwarded to the "If I am busy or my phone is unregistered, forward calls to:" destination.
    What is the destination "If I am busy or my phone is unregistered, forward calls to:" for the extension?
  6. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    It was set to voicemail. I had someone from 3CX connect to my PBX (Teamviewer) and sort the issue out. All sorted
    Dan
  7. apostolis_3CX
    Nov 1, 2017
    149
    15
    Glad to hear your issue was resolved.
