3CX Update
Discussion in '3CX Phone System - General' started by alex_omega, Mar 15, 2008.
  1. alex_omega
    Mar 10, 2008
    5
    I have downloaded the latest 5.1, it shown up with 5.1.4128.0 after running the updater it updates to 5.1.4287.
    But in the loginscreen and the serverstatus still 5.1.4128.0 is written. Is the update correct?
    regards
    Alex
  2. techknows
    Mar 15, 2008
    7
    I believe you are up to date.. I had the same issue working late last night; however the patch didnt fix the call forwarding issue with a busy phone =P
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Yes. Even update success, at both loginscreen and the serverstatus still shows 5.1.4128.0
    However, if you restart the services, it will shows the new version at console log.
    00:43:54.523 CallCtrl::thread [CM501007]: *** Started Calls Controller thread ***
    00:43:54.513 CallMgr::Initialize [CM501002]: Version: 5.1.4287.0
    00:43:54.513 CallMgr::Initialize [CM501001]: Start 3CX PhoneSystem Call Manager
    00:43:54.513 LoadLicenceInfo [CM501009]: License Info: Loaded Succeeded
