Solved 3CX using Thinktel SIP Trunking - Incoming fails with a 403
Discussion in '3CX Phone System - General' started by John R, Jun 22, 2017.
  1. John R
    Jun 22, 2017
    We're using a 3CX v15.5 system, and I've configured Thinktel SIP trunks as per the guidelines published by 3CX. My outgoing trunks work as expected, but I receive 403 errors on the incoming trunks. The Firewall Test ran clean.
    Anyone have similar challenges with this combination? Any recommendations on next steps?
    Cheers
  2. John R
    Jun 22, 2017
    Just discovered the Thinktel IP had been black-listed by my 3CX ....... removed the IP and all works fine.:D
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    Glad to see the issue in resolved and thank you for sharing your solution
