Solved 3CX V 15.2.5.127 app crash iOS 10.2.1
Discussion in 'iOS' started by Tomas C, Feb 10, 2017.
  1. Tomas C
    Dec 2, 2016
    this beta version is crashing immediately after launch. Anyone same issue?
    Already did some reboots of iOS.
    Device Info
    Phone Model: iPhone 6, model A1586
    Generation: 4G
    Firmware Version: 10.2.1
    Jailbreak: no
    Cydia Installed: no
    Issue Info
    Handset: iPhone
    Contacts: local
    Connection: wifi/4G
    Server: External
  2. agp
    agp 3CX Team
    Aug 19, 2015
    134
    19
    Hi Tomas C,
    Could you please try updating to the latest 15.2.5.130 beta and see if that works for you?
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    61
    Hi Tomas
    Apple Test Flight management reports "0 crashes" for 15.2.5.127, so we cannot check (at least not yet) what's about.
    As agp recommended, please try the latest beta, 130.
    Also, as a general recommendation, at any time you can toggle between the "beta" version and the "official" one from the App Store.
  4. Tomas C
    Dec 2, 2016
    Since the app is crashing, I cant see which version it is, so I just looked at the latest Testflight invitation email.
    Is v15.2.5.130 already distributed on Testflight?
    I indeed rolled back to the public 15.2.4.122 :)
  5. Vali_3CX
    Dec 12, 2008
    1,416
    61
    The recommended approach is to check directly the Test Flight app, it shows the current version. E-mail is sent only once, when beta program is started (that means, when it's a new version) while Test Flight is updated (and notifies you via iOS notifications) everytime a new build of that version is available.
    Yes, build 130 is already on Test Flight, and today/tomorrow we'll upload 132, containing some fixes.
