3CX v1.2.12 on Milestone one way audio in GSM
Discussion in 'Android' started by valard, Aug 18, 2011.
  1. valard
    Aug 18, 2011
    I've found strange issue in 3CX voip phone v1.2.12 installed on Motorola Milestone v2.2.1.
    When 3CX phone is active, all GSM calls (incoming and outgoing) has one-way audio (I hear all conversation but the other side doesn't hear me). I found simillar issues only on VoIP, but now this happends only in GSM calls (voip has two-way audio and works without problems). I've tried to use handset and Jabra mobile headset - without result. When I shut down 3CX, everything back to normal.
    Anyone found simillar problem ?
