3CX V10 server, myphone website doesnt work
Discussion in '3CX Phone System - General' started by SFX Group, Jun 20, 2011.
  1. SFX Group
    Jun 20, 2011
    16
    Hi all
    Installed v10 3CX on 2008 Server (x64), using IIS, all working (management site), however if i try to use myphone (website), says theres a communication error.
    I have iPhone clients working, Windows clients version, however i cant get this "myphone" website to work, i get the login box, however the ID and password is correct but it says theres a comms error.
    Tried this with server and client PC firewalls off, same problem, however with firewalls on the client 3CX and server 3CX all work as designed (its not a firewall issue).
    It had to install.NET4 on the server, so how do i debug this issue? Server is 64bit. I have the same issue using IE as Firefox, however as it uses silverlight i assume its IE only!
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    try restarting all 3CX Services and try again.
  3. SFX Group
    Jun 20, 2011
    16
    Restarted whole server, everything works (management) except this bit..... :x
  4. davidbenwell
    Apr 27, 2010
    704
    Hi, I have sent you a PM
  5. SFX Group
    Jun 20, 2011
    16
    Thanks for the offer, i will look at this when i know the rest of the system is ofvia usage (no VOIP connected tto it as yet).
    However i am not based i nthe UK (which i assume you are)?
  6. davidbenwell
    Apr 27, 2010
    704
    We can provide remote support to customers in any country
  7. SFX Group
    Jun 20, 2011
    16
    SOLVED
    Windows update with all .NET 4 updates has fixed the problem.
