3CX V10 SP3
Discussion in '3CX Phone System - General' started by gi@gilomen.ch, Sep 19, 2011.
  1. gi@gilomen.ch
    Jun 8, 2011
    i think there are several new bug in there. Voicemail do not work anymore. Another problem is callerid will not send to another phone (you will get only the internal numer nNOT the number of the external caller).
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Just tested SP3 on our installation and all is working fine.
    could you post the logs here for us to see?
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, can you provide a full description of your problem?
  4. gi@gilomen.ch
    Jun 8, 2011
    the problem ist (SP5) if make a blind transfer the external %callerid% will be transferred correctly. But if you make a attened transfer only the internal caller ID will be transferred. In Rel 9 it works fine first you get the internal caller ID after the transfer the external caller ID will be transmitted. Since rel 10 it will not work!
