3cx v10 spk6 - sip trunk are conec/discon every time!
Discussion in '3CX Phone System - General' started by jr3151006, Apr 2, 2012.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I´m facing too many times a day our 2 sip trunk disconnect/connect every time...
    I found this information in 'Server Activity Log':
    Code:
    15:15:16.564  [CM506004]: STUN request to STUN server 96.9.132.83:3478 has timed out; used Transport: [ V4
    192.168.1.244:5060 UDP target domain=unspecified mFlowKey=0 ]
    What it means????
  2. jr3151006
    Jul 30, 2010
    155
    Another curious entry:
    16:55:25.408 [MS101003] C:89.2: Possible firewall problem. Address mapping failed on STUN server 96.9.132.83:3478 for local address ":9008"
  3. leejor
    10,368
    228
    Are you sure that is a valid IP, I can't find anything on the destination (96.9.132.83)?
    Have you run the 3CX firewall checker lately?
  4. jr3151006
    Jul 30, 2010
    155
    The firewall checker shows the following:
    Code:
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <19:18:42>: Phase 1, checking servers connection, please wait...
    <19:18:42>: Stun Checker service is reachable. Phase 1 check passed.
    <19:18:42>: Phase 2a,  Check Port Forwarding to UDP SIP port, please wait...
    <19:19:02>: UDP SIP Port is set to 5060. NO RESPONSE received. Phase 2a check FAILED.
    Application exit code is -2
  5. leejor
    10,368
    228
    You may want to review the port forwarding setting of your router.
  6. jr3151006
    Jul 30, 2010
    155
    Leejor,
    impossible to run the 'Firewall Checker' since it ask to stop the services... so the ports are not listening anymore.
  7. albertc
    Nov 21, 2011
    89
    Which stun server do you use? It seems like your server cannot connect to the stun server you have defined. By default, 3cx uses stun.3cx.com. But I found that is not very reliable. I have been using stun.counterpath.com and it works quite well for me. By the way, if you have a fix IP address where your 3cx server is, you do not need to use stun. You can turn off stun on the network page of 3cx.
    If you have done all that and still having issues. Please stop the 3cx phonesystem and 3cx phonesystem sip/rtp tunnelng proxy and run the firewall checker and post the result here.
