3CX V11 and Patton 4114
Discussion in '3CX Phone System - General' started by pebble1, Apr 15, 2013.
  1. pebble1
    Nov 3, 2009
    Everything was working and I decided to update the Firmware of the Patton from 4.2 to 6.3. Now I cannot make calls. It shows the trunks registered and I can receive incoming calls fine. When I try placing a call I see 0/1 go active for 15 seconds then it tries 0/1 and on until it fails and gives a busy signal.
    The Log shows: "Call or Registration to 8283367688@(Ln.10000@Patton 4114 4xFXO) has failed. [ V4 192.168.50.21:5066 UDP target domain=unspecified mFlowKey=868 ] replied: 502 Bad Gateway; from IP:192.168.50.21:5066"
    I did create a new config file and same result.
    It worked before upgrade, I tried rolling back to 4.2 but it does not work either.
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    @pebble1
    The response "502 Bad Gateway" typically means that the POTS line is faulty in some way (maybe not connected). Port number 5066 indicates (typically) the 4th port - is there a line connected to port 4?
