3CX V12 "3CX PhoneSystem Database Server" fails to start
Discussion in '3CX Phone System - General' started by Ase, Feb 12, 2014.
  1. Ase
    Ase
    Jan 12, 2009
    58
    After latest Windows updates I ran today the "3CX PhoneSystem Database Server" service failes to start with error: "Error 193: 0xc1"
    I already tried to uninstall 3CX and reinstall again, but after reinstallation the Database service fails with the same error.
    Ideas?
    //Ase
  2. inteq
    Jan 8, 2013
    42
    My guess:
    See what the service tries to start, if the executable exists and if there are some extra " in the command line.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Usually, this error means that the system cannot open and read existing executable file and, therefore, is failed to verify file format.
    A good example is the "exe" file which contains 0 bytes...
    ERROR_BAD_EXE_FORMAT(193/0xc1) and ERROR_FILE_NOT_FOUND(2/0x2) are different :(
  4. Ase
    Ase
    Jan 12, 2009
    58
    Hi Guys,
    Thanks for your suggestions, I was in a hurry and could not troubleshoot enough.
    My sollution was to upgrade Windows Server to 2012R2 and after that 3CX worked again.
    //Ase
