3CX v12.5 click to call with tel protocol
Discussion in 'Windows' started by charles_OF, Aug 29, 2016.
  1. charles_OF
    Aug 26, 2016
    Hi all,
    I have setup the default application to use 3CX Phone for Windows by following this http://www.3cx.com/blog/voip-howto/tel- ... -3cxphone/ and it would not trigger a call when I tried testing the tel protocol. I've done a bit of reading but could not get a clear answer on this one, is it true that the click to call with tel is a feature built for v14 Pro and not under 12.5 Pro?
