3cx v12 in windows 8
Discussion in 'Windows' started by hiyas, Jan 9, 2014.
  1. hiyas
    Aug 22, 2013
    6
    will 3cxphonesystem version 12 works in windows 8?
    11,123
    330
    For the Phone System (PBX), see...
    http://www.3cx.com/blog/docs/supported-windows-versions/
