3CX V12, Recording twice ?
Discussion in '3CX Phone System - General' started by jed, Aug 18, 2013.
  1. jed
    jed New Member
    Feb 1, 2010
    133
    37
    I´m testing seamles call to my mobile, and see that the call is recorded twice, is this by design?
    16-08-2013 17:00:39 xxxxxxxx dail in: CallGroup -> Ext • Answered • Ring time 15 sec • Speak time 14:49 • and a Recording (13,5Mb)
    16-08-2013 17:00:40 xxxxxxxx dail in: My Cell Phone • Answered • Ring time 14 sec • Speak time 14:50 • and a Recording (13,5Mb)
    I did pickup the call on my CellPhone
    It is great that the call is recorded, however we might need to expand our Harddisk capasity, if this is by design...
    /Jesper
    10,375
    231
    It's as if it sees the call going to, and being answered by, two individual endpoints.
    How are you routing the call?
    If it is some sort of a bug, the folks at 3CX are going to need to know that.
    Was this a cut and paste, of the log? The reason I ask, is the word dail, is that supposed to be dial ?
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Are you describing a forwarding rule to your cell phone, or are you answering the call using the 3CX app on our smartphone?
    If the former, you effectively have two calls running against your PBX.. one for the incoming call and one for the call the PBX made to your cell.. explains the "twice" bit. If the latter.. a bug?
  4. jed
    jed New Member
    Feb 1, 2010
    133
    37
    Thanks both for your answer.
    It is written manually after the "Reports".
    Thanks for pointing out the spelling error, there is pleanty of those from where that came, as my english is rubbish. We speak Danish here, not that it makes my spelling better :oops:
    I just added the "Ring my extension and my Mobile at the same time", and the "issue" raises when I pickup the call on my Cell Phone (not through the App)
    The incomming Call is routet through my SIP Provider, and the forwarding is routed to my Mobile through the same SIP Provider.
    When I pickup the call on my Yearlink Phone, I do only record once
    When I pickup the call on my CellPhone, I record twice
    OK, this might make sense, but not a lot of free space on the server ;)
    Thanks again, I will have to close this with, it is by design.
    /Jesper
