3cx v12 softphone
Discussion in 'Windows' started by Mikee, Feb 7, 2014.
  1. Mikee
    Mar 26, 2013
    6
    Hi we are testing the 3cx v12 softphone over a VPN connection i cant seem to get any audio using the new v12 softphone client.
    When i configure a alternative softphone like X-lite everything works fine ................
    Is this a bug or something ?
    anyone got this working or experiencing the same problems ?
    11,083
    325
    Perhaps a bit more information...
    Using the 3CX phone with... the 3CX PBX?
    Does it work when not using VPN?
    Have you tried it on more than one PC?
  3. Mikee
    Mar 26, 2013
    6
    3cx phone v12 with 3cx v12 PBX, localy on the server it got it working and have audio. but from an remote location (WAN) i cant seem to get any audio i tried using a VPN and the 3cx tunnel but no success, the phone seems to register properly but no audio.
    I also tried opening up the firewall (5060, 9000-9049) still no audio , X-lite is working fine in all scenarios
    tried different setups and pc`s still it is strange that X-lite is working fine
  4. leejor
    11,083
    325
    Have you tried this from more than one remote location?
    It's odd that X-Lite works, which would indicate that the audio ports are not being blocked.
