3CX V14 Cloud Server
Discussion in '3CX Phone System - General' started by ericosborn09, Mar 26, 2016.
  1. ericosborn09
    Dec 3, 2015
    30
    After provisioning a new instance, how do you change the recordings and vm quota? I seemed to be locked at 1025mb
  2. 12494
    12494 Member
    Apr 16, 2010
    280
    20
    There are 2 screens in the management console where you can set limits. Default is unlimited.
    Allen
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,243
    61
    In the Virtual PBX installations, you can only set the Quotas upon the instance creation, so if you need to change it, you must backup the instance, remove it, create a new instance, set new Quotas, then restore the backup.
  4. ericosborn09
    Dec 3, 2015
    30
    Ouch, learned by lesson on this one. Do you see any changes coming to this in the future?
  5. NickD_3CX
    Jun 2, 2014
    1,243
    61
    I couldn't really say, I haven't heard something about this, but you could post this in the 'Ideas' section as a feature request.
  6. NickD_3CX
    Jun 2, 2014
    1,243
    61
    You can set the Quota to 0, which is unlimited, upon creating the instance, and in regards to the separate disks for Recordings, check out Symbolic Links in Windows... Haven't tried it myself for stability, but they sound like what you want.
    In regards to changing the Quota, I haven't heard anything about that, but for now whenever you need to change you will have to recreate the instance.
    Also, although it may not be very convenient, but there was a security vulnerability that could be exploited if each instance hod writing access to anywhere on the system.
  7. opalbusiness
    Jul 26, 2016
    Yet another reason we are leaving 3cx. Something as simple as a recordings quota needs changed, and your answer is backup and restore the pbx to a new instance. No thanks, we'll just find a product with competent developers.
